Watercooled, modded NZXT Phantom 530 (1st build BTW)
chos5555
love the way you have gone all ham on that cable management ,looks beast ...
Thanks
Update:
Ok, so finally after like 3 days of work it is here
I got the covers from my grandpa, the plasti dip and put everything together!!!
Let's get to it shall we?
Look at the covers
From the other side xD
I just put it to the case to get an idea what am I dealing with
I removed the protective foil or whatever it is called  and already drilled 1 hole for the screws that will be holding it down
From another angle
I got all the holes for the screws that will hold it drilled :) 2 at the top, 2 at the bottom
The tube is pretty badly crooked though
I was bored so I made a model of how the loop will look(made it in school :D)
Also I will rotate the flow of the water... that means rotate the CPU block, I made an arrow on the drawing :)
0ZB0uGL.jpgI cut a piece under the mobo tray out... you will see why on next couple pictures
The hole from the front
1TTtMlY.jpgNow you can see what I will do with that hole
pP7U1Nx.jpgAnd from the back... the hole comes into play
4pYSo0z.jpgI mounted the HDD with 4 screws so it holds even in an angle
oRL9G5k.jpgCloseup on the holes and screws
8v5BWQ0.jpgI got this in mail... what can it be??
iT6r2Kz.jpgIf you guessed plastidip, you guessed right :)
cHCqtgR.jpgIt is rebranded performix plastidip :)
Cd9f9an.jpgOne of them didn't have a fat cap?? LOL? What if I ordered one and they game me a one without it? I of course have some from the time I was into graffiti LOL
gyWP6Xn.jpgYou remember the crooked tube? I won't leave it like that of course
vHfXOqI.jpgThe hole was perfect for my tube :) this was just a scrap piece, not the actual piece in the build
rygZzh3.jpgI messed up the first few coats :( I will have to add few more so it is even and without any cracks or holes in the paint
Though I had to try if the HDD looks good :)
HsJfVaj.jpgI just put it into the PC to see how it looks
50BhabI.jpgThis mess was in my room when I was doing it :)
50BhabI.jpgPerfected coating... it is better if you do not count the massive crack in it... though you won't see it, so I didn't want to spend another 2 hours on it
mXufQka.jpgAnd I even took apart the loop and poked the tube through the hole when all the paint dried and I installed the HDD
ZLba23e.jpgIt looks pretty nice I'd say, but it is not the end
A4WR9EI.jpgJust showing the back with the wires attached
fA42Vfa.jpgDo you see anything extra in the case now?? Yes I painted and put the cover next to the silver rad in there
B4hiu5w.jpgCloseup  It is nicely hiding all the wires I had there... just does what it is supposed to do... "covers" it
The back of the cover... do you see all the cables in there?
1syOepV.jpgNow comes the hard part... look at my messy cables... I won't be able to do much with those... there is just so many of them, it won't look really good, but I will try
0h76hoo.jpgI've done my best, I swear... at least I can close up the panel without problems
Better look at the cable management
kkV6uaU.jpgFinal look at the nearly finished build, pretty sexy hah? BTW did you notice the cover for the bottom fans next to the PSU cover? I will leave that shiny and reflective, I think it will look good with the pump and res on it
So, this is all I have for you for now
Let me know how do you think it has turned out....
I will get the rest of the parts 7.4.2014(day/month/year) so stay tuned and do not forget to follow if you like the build and you would like to see everything
Cheers, Chos
I really love this build ;D
The only thing that bothers me is that you have your mouse up on the desk and keyboard on a little thing underneath xD
Main Rig: Cpu: Intel Core i7 4790k CPU Cooler: NH_d15 GPU: Gigabyte Radeon HD7970 Windforce III MOBO: Msi Z97 Gaming 5 RAM: HyperX Fury 1600 8gb white SSD: Samsung 840 evo 250gb PSU: Corsair CX750M Case: NZXT H630 white
PC peripherals: Monitor: Samsung Syncmaster T27B550 Keyboard: Logitech G105 Mouse: Logitech G700s Headphones: Logitech G430
Haha, I didn't think of that :) but on the slide out shelf isn't space for the mouse and the mousepad, still it is more comfortable like this ;)
Thanks though
Tommorow I will get the rest of the stuff :3 Stay excited
Quick update: better plan of the loop
post-21779-0-21532200-1396937816_thumb.j
and: my appologies for that the logistics company is late... the stuff will be here today or max tommorow
I would of made it a sleeper build and put it all this in the HP Case haha Nice work!
haha yeah :D thanks
