help HELP Can I put an R5 340X 2GB into a PCI-Express 2.0 X16 Slot?
The video card has a pci-e x16 edge connector, but uses only 8 pci-e lanes to communicate with the computer.
Even if you have a pci-e 2.0 x16 slot with 16 lanes actually in it, the video card can only use 8 pci-e lanes in that slot.
The video card will run in pci-e 2.0 slots, and probably also in pci-e 1.x slots, but the bandwidth will be reduced.
You get 970 MB/s on each pci-e 3.0 lane, but only 500 MB/s on each pci-e 2.0 lane.
So this means the video card will have 8 x 500 MB/s = 4 GB/s between it and the computer, instead of around 7.5 GB/s had you used a motherboard with pci-e 3.0 slots. In real world, the video card is so slow and old, that it won't make a difference.
So you could plug the card in a pci-e x16 slot, you could also plug it in a pci-e x8 slot if you cut the extra empty space in the edge connector (there's no contacts there, the card comes with a x16 wide edge connector simply because it's the most common and reduces confusion (people could say oh it's a pci-e x8 slot, i only have x16 slots and won't buy it)
IMHO you shouldn't have bought it, the were probably much faster video cards that consume maybe just a bt more power and you probaby could have used a molex/sata - pci-e 6 pin adapter cable to power a video card that requires a bit more power than what the slot can offer.
