Search In
  • More options...
Find results that contain...
Find results in...
Left AIO in car in cold weather
Accidentally left my Lian Li Galahad AIO in my car last night. Lowest temp it got to was 16 degrees. Is it going to be okay? I’ve heard mixed things. Most people seem to think the coolant won’t freeze until -30 or so
                                  AMD Zen 3 Rig
  • CPU- AMD Ryzen 7 5800x 8 core 16 thread
  • MOBO- MSI B550 Gaming Edge Wifi Motherboard
  • GPU- AMD Reference RX 6800 16GB GDDR6
  • RAM- 16GB TeamGroup T-Force Xtreem ARGB- DDR4-3200 CL16-16-16-38
  • STORAGE- Samsung 980 Pro PCIE4 M.2 NVME 250GB SSD(Boot Drive) / Samsung 860 Evo 500GB SSD (Game Drive #1) / Sk hynix Gold S31 500GB SSD (Game Drive #2)
  • PSU- EVGA Supernova 850G3 Gold fully modular
  • COOLING - Lian Li Galahad 360mm AIO Silver(Kryonaut) +2x BeQuiet Silent Wings 3 140mm PWM
  • PERIPHERALS- Razer Viper Mini+ X-raypad Equate Mousepad+ custom build mech keyboard- NK65 Watermelon- 67g Tangerine Switches- PBT Keycaps
  • MONITOR- Gigabyte G34WQC 34 inch ultra wide 3440x1440 144hz VA 1500r GSYNC
  • AUDIO- Philips Fidelio X2HR
  • AUDIO- Blue Snowball USB (Textured White)
  • EXTRAS- Custom sleeved Ensourced power supply extensions+ Custom ColdZero SSD Covers
    •         M1 Macbook Air
    • Gold Color
    • Apple M1 Chip- 8-core CPU/7-core GPU
    • 8GB Unified DDR4 Ram
    • 2560x1600 P3 Wide Color IPS Retina Display
    • 256GB SSD
    •       Iphone 11 Pro A2160
    • Matte Gold Color
    • Apple A13 Bionic- 6-core CPU/4-core GPU
    • 4GB Ram
    • 2436x1125 Super Retina XDR OLED, HDR10
    • 64GB Storage
    • IP68 Water Resistant
    • Triple 12MP Cameras (f/1.8- wide) (f/2.0- telephoto) (f/2.4- ultra wide)
    •     Apple Watch Series 4
    • Space Grey Color
    • Apple S4 Dual Core CPU
    • 1GB Ram
    • 448x368 Retina LTPO OLED
    • 16GB Storage
I assume you're talking in degrees Fahrenheit?
If Fahrenheit: should be okay I guess, these items do have to be designed to be carried on a truck in winter weather too.
If Celcius: that's totally fine.
Honestly, I'd just give it power and run it for a day not attached to your computer.  It might be going too far, but I'd take water-based markers or something that will smear/spread when it gets wet and draw yourself a quick n dirty grid or scribble doesn't really matter.  Place AIO over paper check next day for drips and changes to the lines?
That's all i can think of other than sayin F it. and yolo'  it with your PC which I wouldn't recommend.
Edited by illavbill
typo
It’s Fahrenheit. I assume lian li uses add ins that lower the freezing point?
                                  AMD Zen 3 Rig
    •         M1 Macbook Air
    • Gold Color
    • 256GB SSD
    • Matte Gold Color
    • 4GB Ram
    • 64GB Storage
    • Space Grey Color
    • 1GB Ram
    • 16GB Storage
But if they don't, water expands as it freezes so you could have a micro crack in a seal or one of the solder joints on the radiator.  New AIOs are pretty dang resilient.  I'd call Lian Li and verify or just run a little experiment over night.  Might actually need a heat source on the block to heat and expand/ put pressure on the liquid in there.. that or aim a blow drier at the radiator to build a bit of pressure up from the heat.  I had a HUGE hole in my car's radiator, but until the water got hot enough to build pressure nothing leaked.
I would advice doing same as with everything with freezing risk. Keep it in room temps for day or two before powering it. The thing being closed means that even freezing doesn't bring foreign material into it, nor should it remove particles from other parts of the loop. But powering it with liquid possibly frozen (not even fully) and in contact with mechanical parts can cause issues.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
