Laptop HDD Continuous Ping noise
Tech Reprise
Laptop hdd is making a ping noise when screen turns off on battery.
The hdd is a Seagate ST1000LM035-1RK172
Laptop is less than 4months old.
19 Jan, 8.24 pm.mp3
  • AMD Ryzen 7 5700X Stock
  • B550 Aorus Elite V2 Rev1.2
  • G.Skill TridentZ RGB 3600Mhz 32gb (8gb x4)
  • MSI Mech 2X RX6600
  • Deepcool AK620 WH
  • Deepcool CK500 WH
  • Kingston A2000 250gb + WD Blue 1tb HDD, Sn550 1tb + MX500 1000gb
  • Antec EAG Pro 750 80+G
  • Benq Mobiuz EX2510 144Hz
Sound a bit like the HDD spinning up repeatedly and the head moving into its parking position in between. Have you checked the disk for errors (e.g. CrystalDiskMark). It might've gotten damaged e.g. by a fall or similar.
Yes, everything is fine. HdSentinel, CDM, even Sea Tools shows no error.
Can it be because of laptop trying to save battery by spinning the hdd down?
  • Deepcool AK620 WH
  • Deepcool CK500 WH
Could be, but then the noise should only happen "once". The HDD should shut down e.g. after x minutes, depending on your energy settings in Windows. You should hear it spin down and the head move into its parking position but that shouldn't repeat periodically unless the HDD spins up in between.
