Fan with it's own power supply.
Solved by Kilrah,
53 minutes ago, Maury Sells Wigs said:I only have a 500w PSU and I'm not sure if getting a 4 pin splitter and using that to plug another fan directly into the motherboard is a good idea as I already have one more fan plugged in than came with the computer.
A fan draws almost nothing so if that caused a problem your PC woudld already crash all the time.
5
throwaway60540 ·
Posted in Graphics Cards7 -
HelloFriend ·
Posted in Troubleshooting1 -
2
TurleyV16 ·
Posted in Troubleshooting3 -
Rumman ·
poly ·
Posted in General Discussion4 -
10
play_circle_filled
Latest From Linus Tech Tips:
He Spent 3 YEARS Begging me for a PC. Good Luck Finding it!
