Samsung C27JG5X settings issues
NINJA_F15H
Hi guys,
As you can see eye saver mode and most of the settings on my monitor are greyed out on my Samsung C27JG5X. I've looked into OSD lock but apparently eye saver mode etc, should still work when OSD lock is enabled and holding down the Jog button for 10s or longer which turns OSD on or off appears to do nothing whatsoever. Tried plugging into partners PC and tried different ports on my graphics card to no avail. When I first purchased the monitor there were no issues at all. Only been in the last couple of months that the issue has presented itself. On a bit of a side note, as you can see on the first image randomly when turning my monitor on the left half will be completely black, this can be fixed by cycling through sources until coming back round to DP but was wondering if this could be the monitor trying to tell me its giving up on me. Any help would be greatly appreciated.
Thanks,
NINJA_F15H
OSD: Go to system. Reset ALL. Update firmware perhaps
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: G.Skill Aegis 2x16gb 3200 @3600mhz | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Red Devil RX 7900XT | Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: MP510 960gb and 860 Evo 500gb | Cooling: CPU: Noctua NH-D15 with one fan
FS in Denmark/EU:
Asus Dual GTX 1060 3GB. Used maximum 4 months total. Looks like new. Card never opened. Give me a price.
System only allows me to exit the menu entirely. I'll see if I can find a firmware update
On my old samsung - it was completly down to the bottom in system
FS in Denmark/EU:
the only selectable options are PC/AV and DisplayPort Ver. no other option will highlight
Are you sure you cant go down further? My display had same panel and OSD menu. But in any case, try updating firmware. Was necessary with my monitor too..
FS in Denmark/EU:
No as you can see in the video they are the only 2 option available
  • 2 months later...
I had the exact same issue on my C32JG50 which I had connected using DP. Switched to HDMI 2 (to get the full resolution at 144hz) and I am able to access all the OSD menu. Tried going back to DP even with a different cable, no go, it goes back to the "locked" mode. Have tried to reset to factory default but DP connection is somehow causing this lock. So now I stick with HDMI. Hope this works for you.
