My graphics card fan is not spinning
Harlon
I have an EVGA 1060 3gb single fan and i took the casing off to mod it and then put it back on and the fan isnt working. i made sure that i plugged in the fan. i even tried unplugging and re-plugging it in but nothing works. it spins a tiny bit when i start up my computer and then it just doesn't go, not even when i am play games. Can anyone help?
If the GPU stays under 60c it won't spin by default.
"Black Out"
1tb Samsung 970 Evo | 2x 2tb Crucial MX500 SSD | Fractal Design Meshify S2 | Corsair HX1200 PSU
Dedicated Streaming Rig
 Ryzen 7 3700x | Asus B450-F Strix | 16gb Gskill Flare X 3200mhz | Corsair RM550x PSU | Asus Strix GTX1070 | 250gb 860 Evo m.2
Before i took it apart it was spinning all the time.
what are your temps like?
"Black Out"
At idle, 39 c. in minecraft, around 50 c. and in like fortnite, around 65-70 c
Do you use MSI Afterburner or EVGA Precision X1? Try manually turning the fan on and setting it to see if it will spin.
"Black Out"
i use nzxt cam. how do i manually turn on the fan?
You can't with CAM. Go download MSI Afterburner and use that.
"Black Out"
ok. i will do that now
thank you. it works now. i set it to max at first and it scared me it was so loud!
