AIO Pump & Fans RPM
Solved by jwwagner25,
21 hours ago, Ejayy said:Hi,
Yes, its ID-Cooling, the 900rpm one is my Fan at the rear I had to connect it to the motherboard. Do I need to set a fan curve for my AIOs fans or should i just set it to default its kinda loud when its on 1795 rpm.
you definitely could set a curve. I ended up using the fancontrol app posted on the forums here, it's amazing. very lightweight and sets everything automatically on boot.
I would do a simple graph where the fans are at their lowest speed until the cpu gets to maybe 70 degrees, then go to 90 or 100%. since you have a 360rad it will take a long time at idle for the water to warm up, the passive cooling ability of that size radiator is very good.
best of luck,
jake
