lian li 011D fan layout
Cartridge
I'm currently planning a new build for a lian li 011d air cooled build. ryzen 5900x and a 3080 on an Asus TUF x-570 plus board. Want to do at least a little rgb (bc obviously im a basic bitch) and read somewhere if I do intake on the side I would need corsair ql 120's to be able to see the rgb on the intake side. Is this true? Watched the breakdown on gamer's nexus and saw if only three fans, then that was the proper placement, but I was curious about what to do 6. Should I put three non-rgb fan on the bottom for additional intake? Or three fans on the top for exhaust? I think the mobo only as slots for three fans so would it be best to get the commander pro to have full control over fan curves? If so, is it only compatible with corsair fans or would something like noctua work just as well if I didnt want all the extra rgb?
Thanks for the help!
The reason QL would be nice on the side is that they have RGB on the back too. It will still look OK on the side if you don't choose QL. As for the commander pro, I don't know if anything other than Corsair fans will work with it. but my guess is not.
“Appear weak when you are strong, and strong when you are weak.” - Sun Tzu, The Art of War #muricaparrotgang
Tier Lists and Specs List Below
Motherboard VRM tier list  -----  PSU tier list
React if you agree with me!
CPU: Ryzen 5 3600  |  CPU Cooler: Asus ROG STRIX LC240 White |  RAM: Crucial Ballistix RGB 16GB 3600 | Mobo: ASUS ROG STRIX B550-A  |  SSD: Inland m.2 NVMe SSD 256GB  |  HDD: Seagate 2TB 7200RPM |  GPU: RTX 3060 Ti FE  |  PSU: Seasonic SGX 650 |  Case: Lian Li o11 mini-W  |  Mouse: Razer Basilisk mercury |  Keyboard: Drop CTRL (Used. I did not spend $200 on a keyboard) |  Mouse Pad: Aura Mech Purple Storm  |  MonitorAsus TUF 24" IPS 144Hz 1080p
Should be able to put 3 120's on bottom of the case, 3 on the sides and 3 on the top if its the mid tower. I am currently building in the case as well with 9 Unifans though
Are you daisy chaining them I'm assuming? First time doing anything llike this, Trying to wrap my head around it before I get to building.
Where did you get the UNI fans? And at MSRP? Either the QL or the UNI would be a great fit for a O11 -D model.
