No screen output after running "New CPU installed" F1 setup (first ever boot)
Solved by FoxTrotte,
Okay this is solved!
We figured out that the first GPU we used (his GPU) probably died after the first bios setup for some reason, and the reason why we couldn't boot with the second GPU was that we had only plugged one out of the two necessary power cables
noidea213 ·
Posted in Graphics Cards0 -
TheNaitsyrk ·
2
12345678 ·
Rummers ·
Posted in New Builds and Planning4 -
a7med ·
Posted in CPUs, Motherboards, and Memory1 -
7
1
moondogkill ·
Posted in Cooling3 -
1
play_circle_filled
Latest From Linus Tech Tips:
Every Monitor Fails This Test… Except One - Sun Vision rE rLCD Display
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
