The PC user's Mac 5700XT Pro - Sapphire announces passive Radeon 5700XT
williamcll
x070_serverroom_960x603_01_3sep20.ashx
Designed for use for server racks, the GPRO X070 is a solid passively cooled card for those that want mid-range server rendering or late to the mining craze.
Quote
The card is based on Radeon RX 5700 XT SKU featuring Navi 10 GPU. This model features 40 Compute Units with 2560 Stream Processors. Sapphire’s GPRO model is equipped with 8GB of GDDR6 memory clocked at 14 Gbps. In terms of GPU frequency, the GPRO X070 features AMD reference specs of 1607 / 1755 / 1905 MHz (base, game, and boost clock respectively). The fact that this card has a game clock listed in official specifications may sound strange considering that the card is designed for a professional workload, but technically, this is just a custom Radeon RX 5700 XT. Interestingly GPRO X070 has a secondary BIOS with ‘Efficiency Mode’. In this mode, the clock speed is reduced to 1500 / 1700 / 1750 MHz with the memory clock kept at 14 Gbps. It is unclear what exactly is the purpose of this mode, but reduced clock speeds are often seen in graphics cards in mining environments.
Source: https://videocardz.com/newz/sapphire-releases-gpro-x070-a-fanless-radeon-rx-5700-xt
https://www.sapphiretech.com/en/commercial/gpro-x070-gpu-compute-graphics
Thoughts: It's useful for people that want a more affordable openGL/Vulkan rendering server. Though I guess it would still be hard for the typical user to get one on most websites.
Specs: Motherboard: Asus X470-PLUS TUF gaming (Yes I know it's poor but I wasn't informed) RAM: Corsair VENGEANCE® LPX DDR4 3200Mhz CL16-18-18-36 2x8GB
            CPU: Ryzen 9 5900X          Case: Antec P8     PSU: Corsair RM850x                        Cooler: Antec K240 with two Noctura Industrial PPC 3000 PWM
            Drives: Samsung 970 EVO plus 250GB, Micron 1100 2TB, Seagate ST4000DM000/1F2168 GPU: EVGA RTX 2080 ti Black edition
I don't see the point of this for normal consumers unless its significantly cheaper than a normal 5700xt. Its more designed for high airflow applications.
I will recommend an NHu12s (or an NHd15 (maybe)) for your PC build. Quote or @ me @Prodigy_Smit for me to see your replies.
PSU Teir List | Howdy! A Windows Hello Alternative
Desktop :
i7 8700 | Quadro P4000 8GB |  64gb 2933Mhz cl18 | 500 GB Samsung 960 Pro | 1tb SSD Samsung 850 evo
Laptop :
ASUS G14 | R9 5900hs | RTX 3060 | 16GB 3200Mhz | 1 TB SSD
I wonder if it's fine to call it passively cooled when it's designed with expectations that it'll have airflow over the fins?
-sigh- feeling like I'm being too negative lately
Quote
5700XT Pro
seems a little late
Hi
hi
53 minutes ago, Drama Lama said:
seems a little late
It's not like you are going to find a 6700XT on the shelves anytime soon.
18 minutes ago, leadeater said:
Cooler goes above the height of the PCIe bracket, yea that's not actually going to be useful for many servers at all.
My fan cooled 5700XT can reach the mid 90s after a few hours of stressful gaming (and I have a high AF case with 6 fans), this thing is going to cook if anyone tries to actually use it.
Main Rig:-
Server:-
I genuinely can't see a practical use for this. It's not good for airflow-restricted applications because the fucker runs hot and it's pointless for airflow-friendly applications unless silence is a requirement.
I find it amusing that in the picture they have a bunch of servers in the background, which is basically the one application I can think of that a cooler design like this would make sense; servers tend to have passively cooled parts with a few large fans providing airflow through the entire chassis instead of having intake and exhaust fans paired with the fans on the components.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
