Is it ok if cpu fan is running at 5870 rpm?
By
ninjaboyxd629
in Cooling
in Cooling
Solved by Jae Tee,
1 minute ago, ninjaboyxd629 said:i applied thermal paste 2 years ago should i reapply again?
Can't hurt. They do go bad eventually, but you should be on the lookout for anything that may be obstructing airflow. Dust in a heatsink, ventilation holes being covered, stuff like that.
PowerPCFan ·
Posted in Phones and Tablets0 -
gen4re ·
Posted in Graphics Cards3 -
well91 ·
Posted in Troubleshooting1 -
DaMainMan ·
Posted in Troubleshooting0 -
1
Millios ·
Posted in CPUs, Motherboards, and Memory5 -
Geeku ·
Posted in Storage Devices2 -
xRIXCHx ·
play_circle_filled
Latest From Linus Tech Tips:
Why Do Youtubers Keep Destroying Companies - WAN Show April 19, 2024
