No space for my wifi adapter antenna
Jydn
On my Matrexx 50 case I just got there is a mesh covering the gap where my gpu sorta sticks out, but there is no space for the antenna of my wifi adapter card. There is metal bars covering it and they don’t look removable
The PCIe slot covers? They're screwable
IIRC with the Matrexx 50 you need to remove a cover to get to the screws.
CPU: R5 3600 || GPU: RTX 3070|| Memory: 32GB @ 3200 || Cooler: Scythe Big Shuriken || PSU: 650W EVGA GM || Case: NR200P
Thx I’ll try it
17 hours ago, Jydn said:
Thx I’ll try it
There was no cover or screws turns out they just pop off with a bit of force
