How to override headphone jack input on a laptop.
I have an Honor MagicBook 15 which has a combo mic/headphone jack. Whenever I plug in my external speakers the built in mic stops working because there's something plugged into the jack and it thinks it's a microphone. How, and can I even override this so that my laptop uses the built in mic even when the speakers are plugged in?
Get a TRRS to TRS - adapter and try with that. The combo-jack is known as TRRS, whereas the non-combo connector, like e.g. the one in your speakers, is TRS.
I was planning on doing that later but I was wondering if there's a way to do it in software?
Well, is the built-in microphone available in the list of input-devices when you have speakers plugged in? If not, then it's probably a hardware-switch, not a software-one.
Set the default device in the windows sound control panel.
Well sort of, i can choose between the realtek microphone and the stereo mix which just uses the signal going to the speakers and reads it as a mic input and just loops the sound so maybe it is a hardware switch.
