Will the GTX 1060 work on a 300W psu? HP Pro 3300 MT Series
ulitin
the mine cpu is i3-2120
this desktop will be used to test the performance and life of video cards, so probably i will upgrade cpu, but not for now
anyone have experience to run 1060 on 300w psu (or similar 120w cards) ?
perhaps this is a stupid question, in the coming weeks I will purchase a more powerful power supply
I looked for my desktop at the userbenchmark and there a couple of guys did put the GTX 650Ti Boost
Most likely for a stock power supply of 300 watts?
The card has a TDP of 134w and, strangely enough, the minimum power supply is 300 watts (referring to the techpowerup)
well i see my psu has tiny cables and too much "office" in definition. it doesn't smell 6pin here.
I decided that I would buy a good PSU from my friend, thank you gentlemens
