CPU low watt usage on 100% load (Freezing)
Solved by crazytazz,
On 1/18/2021 at 12:42 AM, ShrimpBrime said:right.
so i think i found the problem , i lowered the GPU Clock from 1290 Mhz to 1200 Mhz. For some reason my RX 480 while using Furmark needed 180 W to reach 1290 Mhz and now to reach 1200Mhz it uses 140 W.
OldFord76 ·
Posted in Troubleshooting0 -
Blawe17 ·
Posted in Troubleshooting1 -
Ronbaow ·
zoneeye ·
Posted in Troubleshooting3 -
leclod ·
Posted in Operating Systems3 -
PatRed ·
Posted in New Builds and Planning6 -
3
2
StormBreakes ·
Posted in Build Logs1 -
6
play_circle_filled
Latest From Linus Tech Tips:
He Spent 3 YEARS Begging me for a PC. Good Luck Finding it!
