My cable is gonna melt :( plz help
Solved by kelvinhall05,
Just now, Dumb guy said:Yeah i know, i will upgrade the PSU in a few months but i dont have the money right now ( I just bought the GPU). and i was wondering why is the pcie express not proving 75 watts. Do you know why?
Thanks
The card will only draw all of its power from the PCIe slot if it has no external power connectors. It doesn't prioritize the slot's power.
