Fractal Design Meshify C: Locating Additional (3rd) 3.5" Hard Drive?
Solved by Middcore,
That's the bottom of the PSU enclosure at the front, where the removable 2x3.5" cage goes. I don't think it's so much an additional 3.5" area as it's an alternative one - you can put a single 3.5" drive there screwed directly to the case floor if you aren't using the included cage. Fractal's specs for the case only say it supports up to two 3.5" drives, not three.
