PCIe 4.0 GPU/mobo with a PCIe 3.0 riser cable?
Solved by matt0725,
It should work. The changes made between generations are just how communication happens, it isn't physically any different on the slot, so a riser shouldn't change that either
skkler ·
Posted in Cases and Mods2 -
Iggzy ·
Posted in Troubleshooting1 -
3
11
Gat Pelsinger ·
Posted in Linux, macOS and Everything Not-Windows10 -
7
lightfire ·
Posted in Hobby Electronics1 -
7
5
Trissssss ·
Posted in Laptops and Pre-Built Systems3
play_circle_filled
Latest From Linus Tech Tips:
The BRIGHTEST Monitor We've EVER Seen - Sun Vision rE rLCD Display
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
