Wireless headset for gaming and skype with a retractable mic, suggestions?
Mostly because I find it way more convenient, honestly.
I dislike needing to plug/unplug the headset out of the pc when wanting to listen to my speakers and whatnot.
Also as my PC sits to my right, mostly I find it so inconvenient that the cables tend to run from the left side (like with Siberia v2) over to the pc. I could possibly consider something like a headphones that have the cables running from the right side speaker-side (very confusing explanation. I hope you got it).
I am aware that you could just simply change the main audio device every now and then from within the controls, but honestly? That leaves just the cable issue with Siberia v2.
With that said, should there be a good option with cloth covering on the pads and a microphone to go with that. I am sold, well as long as I do not have to cope with the oddness of the cables running from the left of the headphones over to the pc that stands to my right.
i would so recommend the Func HS 260s for you switchable mic and cable so you can have them on what side you want and you can switch the earcups from cloth to pleather and vice versa
