80c idle after 3 cooler resiting
3 minutes ago, GhostRoadieBL said:- when you press down(towards CPU) on the pump/block combo do the temps go down?
- How do you know the pump is still working (ie the bios/OS is reading pump speed or is it just making noise while running)? This could indicate an empty loop or airlocked pump if the pump is running and no cooling is happening. Can test this by running the pump/fans with the block off the CPU, heat up the plate with your hand (rub your hands together and touch the plate) then turn on the pump/fans and feel for the temperature change on the block.
I assume the fans are ramping up and you've checked the pump and fan curves in the BIOS to make sure the pump is at 100% and not 10% silent or something at 100C.
Okay so I was so sure that I did it well that I left it run a bit longer, and lo and behold the paste actually went bad (my gpu was idleing at 30c after 10 min of idleing but after 30 it started going up and idled at 65c so yeah sorry about the stupid post, but still some weird thermal paste)
how do I delete that mess now? the issue is resolved I ordered some fresh artic 5
