Low FPS in Fortnite with 2080 Super and Ryzen 3800x
AJ999
I got an MSI Ventus 2080 Super for Christmas I have experienced fps problems in Fortnite ever since. However, it works randomly sometimes. When I get lucky I get 200-350fps but every other time I get lower than 80 no matter where at 1440p. When I change graphics from low to epic with raytracing my fps stays the same. My thermals are fine, neither CPU nor GPU is at 100% usage, and only happens in Fortnite and no other game. I would love some help and get this working properly, thanks.
Fortnite doesn't have raytracing so "epic with raytracing" is kind of meaningless.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
Ryzen 7 5800X3D | ASRock X570 PG Velocita | PowerColor Red Devil RX 6900 XT | 4x8GB Crucial Ballistix 3600mt/s CL16
It was added to the game.
@AJ999 Ray tracing is very taxing, changing the preset might not enable or disable it. Try playing the game with custom high settings and disabling ray tracing.
Huh, shows how much attention I pay to Fortnite. Nvidia continuing their brilliant strategy of putting it in a bunch of online shooters where everybody just turns graphical options down for frames anyway.
we dont have enough information to work with here, but here are a few things i would suggest you do.
Install the latest drivers
Reinstall fortnite
Format your pc so that no viruses can intervene
Pretty much. The only RTX tech I ever use is DLSS to make games playable at 4K with 60 FPS vsync on my tv.
3 hours ago, Eddie Murphy said:
Starting up on Borderless window ?
It starts in fullscreen
The FPS doesn't change with or with out so I'm extremely confused
Is your power plan not set to performance perhaps ? what with the new card using more power than the old one the setting may have never been changed from balanced.
Did you uninstall the old drivers before installing the new card? You do this with a program called DDU. Download it, restart windows in safe mode, and then uninstall all the nvidia drivers. You will then need to reinstall the new drivers.
I did a ddu and im still having the same issues
it is on ultimate performance
14 hours ago, Sorenson said:
can you list all your system specs?
Corsair Vengence 3200mhz 16GB cl16
Seagate Barracuda 1TB HDD
Thermaltake Toughpower GF1 850W 80+ Gold
MSI B550 Gaming Plus
Refurbished MSI Venus 2080 Super
Ryzen 3800x
Ryzen 3800x
You have two sticks of ram in the correct motherboard slots running dual channel right?
If you do, my best guess to fix it would be clear your CMOS, reset your motherboard to factory settings, and reset windows. That is a shot in the dark and might not work though.
They are in the correct ram slots, thank you for your help
