Y-Splitter or Fan Hub
Solved by SavageNeo,
you should run the 120mm fans on 1 splitter and the 140mm fans on one splitter
and dude do not plug the cpu fan to sys fan header, it will give you cpu fan error every time you boot
Redsin ·
Posted in Graphics Cards1 -
BTSHalfLifeAndGmodFan2003 ·
Posted in Graphics Cards11 -
1
2
2
4
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
