Gauge of PSU Wall outlet Power Cable
Solved by CommanderAlex,
Welcome to the forums!!!
If your running a Threadripper and a 3090 together, I'd go with a +1000W unit to keep up with the demand. But, you can start with the basics, have you DDUed(nuked) your graphics drivers after installing the 3090? There might be an issue there.
5 minutes ago, matooch said:Is it possible that the power cable I'm using is regulating how much wattage my psu is capable of?
I would have suspected the cable sheathing would start to melt off since the PSU is not going to know what type of cable is connected to it and pull more current than what the cable is rated for.
