Spilt water on my GPU, any ideas??
Solved by _Nessquick_,
3 minutes ago, minibois said:Water and lemonade are a different sort of story.
With water you want to remove as much of it as possible and then let it dry.
Lemonade however has sugar in it. Water dries off, sugar does not and could short out something on the board.
Whenever I encounter anything with liquids spilled on it, my go to is to unplug it and properly clean it. Alcohol + a toothbrush (you won't use in your mouth anymore) is the method I prefer.
yeah, i'll give this a try, thanks.
