CPU cooler upgraded, PC was stuck in boot loop. What was the reason?
Solved by Radium_Angel,
2 minutes ago, MrMikeoxsmall said:Should I loosen it further?
Because if I go further I am afraid it will dislodge randomly and fall off.
No, leave it as it is. When I put on CPU coolers, I use a screwdriver and tighten down until the screw stops moving with a light touch on the screwdriver (basically no more force than I used to start turning the screws to begin with)
