i7 9700K Overclocked @ 5.0 GHZ, cooling with Corsair H150i Pro Aio.
Just now, MarkCRO said:I think that my problem is radiator place, bottom fan on radiator is blocked a bit, about an inch ( 3 cm ) in front of it is the HDD bracket, slided joust to fit a fan, and in combination with push air from inside, plus 3090 is hot as b...ch, plus a got midi motherboard so comonents are close, temps get " stable " when i open one side panel a bit, stable i mena that they are not spiking so much.
Can that config be reason of slightly hight temps?
That can definitely be why you have such high temps.
Every small thing will add to a couple of degrees.
1 minute ago, MarkCRO said:I will test that today, and post here if you want.
One more thing I noticed and wanted to ask.
23 minutes ago, MarkCRO said:Voltages i did not modify, joust XMP profile set to XMP II, and sync all cores to 50
You did not modify the voltage to your CPU ?
Does that mean you still have the voltage in "auto" settings ?
When the voltage is in auto mode it will always use more than what is necessary which would result in highter temps.
