Hotter temps in UHD ?
venomx
Is it normal for CPU temps to increase when in UHD ?
I used to play CP2077 in 1080p, now im in 1440p @ high, my CPU temps are about 65c
Ryzen 5 3600
Noctua NHU12s
What graphics card do you have? If you're loading the GPU more, it's probably increasing your case ambient temperature.
In any case, 65C is perfectly fine.
3060Ti FE
Looking at ryzen master, now i'm in 1440p in high, there is much higher CPU usage so that probably explains it
On 1/12/2021 at 7:07 PM, venomx said:
3060Ti FE
More performance needed to squeeze out from both GPU and CPU, also GPU fan design is moving hot air to CPU cooler, so that also makes CPU run hotter. Anyway, temps aren't issue so it doesn't really matter.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
