Search In
  • More options...
Find results that contain...
Find results in...
10700k... Throttling, but at temps I don't understand.
Go to solution Solved by Jurrunio,
1 hour ago, unclewebb said:
I am not sure what this means. Intel CPUs use full turbo boost right up to the point that they start thermal throttling.
VR shows voltage regulator related throttling. PL1, PL2, PL3 are the power limits. If your CPU is not running at full speed, it is usally one or the other.
SlashedM is thinking about the type of turbo boost behavior on new Ryzen CPUs and GPUs from AMD and Nvidia, in which you lose frequency just because the silicon got warm even if it's still well within Tjmax.
52 minutes ago, Brok3n But who cares? said:
Oh okay, It exceeded the power limit of the CPU. Is that to do with the VRMs or should I increase the power limit? Like should I make any altercations?
Dont raise the power limit if you dont get any VRM temperature readout. Even if it does, only raise it if it stays below 90C.
Hullo,
         I recently installed a i7-10700k in my system [with a 120mm aio in push/pull] and have been overclocking & benchmarking it. Currently it sits at 4.98ghz. When I tested it on applications such as prime95 and cinnebench, it would without fail start to automatically downclock the CPU, even while under 100% load to something of the likes of 3.5-3.75 ghz. Thing is, when I opened hwinfo to look at the CPU temps, they usually hovered around 80c, with the highest being 93c on one core (core 3)- 7c away from TjMax. Should the CPU be doing that/is this normal? If so, is there a way to fix it in the bios? Otherwise, if it's not, how could I diagnose/fix what's going on?
Stats for nerds, if it helps.
Running a 10700k [on a asus prime mobo] at 4.98 ghz right now, these are the settings on it: SVID behavior on worst-case AVX Instruction core ratio... offset 0 CPU core ration limit is on sync all cores, ratio limit at 50 SVID support is disabled ring down bin eabled, min/max cache ratio on the cpu are at 45. CPU vccio voltage and system agent volage are both at 1.23 irrc PCH core voltage is at 1, CPU load line calibration is at level 4, CPU current capacity is at 120% Fixed cpu vrm frequency is at 500khz on manual CPU core/cache current limit max is at 255.75, Long duration pacakge power limit is at 225, package power time window is at 56, short duration is same as long. Speedshift and speedstep are off, Dual tau boost is on. All other settings are on asus defaults iirc
I am NOT a professional and a lot of the time what I'm saying is based on limited knowledge and experience. I'm going to be incorrect at times.
My build:
CPU: 10700k Oc'd to 5.0 ghz                            GPU: RTX 3070 ventus 2x
Motherboard: Asus z490-v                                Cooler: Deepcool castle ex 120mm
Ram: Team tforce delta 32gb 3200mhz cl16     Case: Phanteks p418r (p360a ripoff)
PSU: Apevia Prestige 800w
Notes:
To me the 10700k seems pretty underrated. It's a very solid cpu. at 5.0ghz it draws 175-185w under full load. the Asus z490-v is a sh*t teir motherboard, I wouldn't recommend it for anything past a 10600k for light oc's only. Tforce ram is pretty but cpu cooler clearance can be an issue on them, so beware. the RTX 3070 is obviously a great card, but the ventus 2x is just horrible. Don't buy it, not now, not ever. It's flimsy af, you can't increase the stock power limit, the cooler is worse than the one on the 3070FE. If it's a choice between this and nothing, choose nothing. The deepcool castle ex 120mm isn't really on sale outside of prebuilts, but it's a nice pretty cooler, gets my 10700k up to 96c after a prime95 cpu test for 15 minutes. The p418r is basically what it looks like. P360a, slap a few cyberpowerpc logos on it, and you're golden. The Apevia Prestige 800w is bad, but not terrible. Runs respectably quiet and isn't a bomb. More than a lot of PSU's in prebuilts can claim.
Motherboard Tier List                   How many watts do I need?
Best B550 Motherboards             Best Intel Z490 Motherboards
PC Troubleshooting                      You don't need a big PSU
PSU Tier List                                Common pc building mistakes
PC BUILD Guide! (POV)              How to Overclock your CPU
CPUs throttle at 90C usually, sometimes mid 80s. Did you make sure to remove the plastic from the thermal paste? Are you sure the AIO is seated correctly? Also is it me or 120mm for a 10700k overclock seems like a bad idea, Im pretty sure even stock it runs warm.
EDIT: Yeah its expected, get a better cooler, either with a good air cooler or a good bigger AIO.
Chicago Bears fan, Bear Down
Too many of the wrong details. Which mobo chipset? Use hwinfo and see if it reports some limiter is activating. Also I'd consider 120mm AIO to be not a lot of cooling for a CPU like this.
Desktop Gaming system: Asrock Z370 Pro4, i7-8086k, Noctua D15, G.Skill Ripjaws V 3200 2x8GB, Gigabyte 2070, NZXT E850 PSU, Cooler Master MasterBox 5, Optane 900p 280GB, Crucial MX200 1TB, Sandisk 960GB, Acer Predator XB241YU 1440p144 G-sync
TV Gaming system: Asus B560M-A, i7-11700k, Arctic eSports 34 duo, Corsair Vengeance Pro RGB 3200@2133 2x16GB, MSI 3070 Gaming Trio X, EVGA Supernova G2L 850W, Anidees Ai Crystal, Samsung 980 Pro 2TB, LG OLED55B9PLA 4k120 G-Sync Compatible
Streaming system: Asus X299 TUF mark 2, i9-7920X, Noctua D15, Corsair Vengeance LPX RGB 3000 8x8GB, Asus Strix 1080 Ti, Corsair HX1000i, GameMax Abyss, Samsung 970 Evo 500GB, Crucial BX500 1TB, BenQ XL2411 1080p144 + HP LP2475w 1200p60
Former Main system: Asus Maximus VIII Hero, i7-6700k, Noctua D14, G.Skill Ripjaws 4 3333@2133 4x4GB, GTX 1650, Corsair HX750i, In Win 303 NVIDIA, Samsung SM951 512GB, WD Blue 1TB, Acer RT280k 4k60 FreeSync [link]
Gaming laptop: Lenovo Legion, 5800H, DDR4 3200C22 2x8GB, RTX 3070, 512 GB SSD, 165 Hz IPS panel
C'mon man. I provided temps. If the plastic cover was still on the aio heat sink, I wouldn't be running it at 80c full load lol
My build:
Notes:
8 minutes ago, Brok3n But who cares? said:
Hullo,
  Hide contents
Prime95 or Cinebench is really heavy on the CPU.
A tiny 120mm AIO is not going to be enough for a i7-10700K running OC'ed to ~5.0 GHz.
It doesn't have enough surface area.
You are going to see the Turbo Boost throttle a bit at those ~90*C temperatures.
So just ONE core reaching ~90*C, and the others are in the 80's?
Intel Z390 Rig ( *NEW* Primary )
Intel X99 Rig (Officially Decommissioned, Dead CPU returned to Intel)
  • i7-8086K @ 5.1 GHz (still tweaking) -- i7-6800K
  • Gigabyte Z390 Aorus Master -- ASUS X99 Deluxe
  • Sapphire NITRO+ RX 5700 XT Special Edition -- 2x Sapphire NITRO R9-Fury in Crossfire
  • 32GB G.Skill TridentZ DDR4-3000 CL14 (16GB TridentZ RGB + 16GB Red/Black TridentZ)
  • SanDisk 480 GB SSD + 1TB Samsung 860 EVO + 1TB Intel 660p NVMe
  • EVGA SuperNOVA 850W P2 + Red/White CableMod Cables
  • Phanteks Enthoo Luxe Tempered Glass Edition
  • Ekwb Custom loop
  • Logitech G502 Proteus Spectrum + Corsair K70 (Red LED, anodized black, Cheery MX Browns)
Intel Z97 Rig (Secondary)
  • Intel i5-4690K 4.8 GHz
  • ASUS ROG Maximus VII Hero Z97
  • Sapphire Vapor-X HD 7950 EVGA GTX 1070 SC Black Edition ACX 3.0
  • 20 GB (8GB X 2 + 4GB X 1) Corsair Vengeance DDR3 1600 MHz
  • Corsair A50 air cooler  NZXT X61
  • Crucial MX500 1TB SSD + SanDisk Ultra II 240GB SSD + WD Caviar Black 1TB HDD + Kingston V300 120GB SSD [non-gimped version]
  • Antec New TruePower 550W EVGA G2 650W + White CableMod cables
  • Cooler Master HAF 912 White NZXT S340 Elite w/ white LED stips
AMD 990FX Rig (Decommissioned)
  • FX-8350 @ 4.8 / 4.9 GHz (given up on the 5.0 / 5.1 GHz attempt)
  • ASUS ROG Crosshair V Formula 990FX
  • 12 GB (4 GB X 3) G.Skill RipJawsX DDR3 @ 1866 MHz
  • Sapphire Vapor-X HD 7970 + Sapphire Dual-X HD 7970 in Crossfire  Sapphire NITRO R9-Fury in Crossfire *NONE*
  • Thermaltake Frio w/ Cooler Master JetFlo's in push-pull
  • Samsung 850 EVO 500GB SSD + Kingston V300 120GB SSD + WD Caviar Black 1TB HDD
  • Corsair TX850 (ver.1)
  • Cooler Master HAF 932
1 minute ago, Brok3n But who cares? said:
C'mon man. I provided temps for you. If the plastic cover was still on the aio heat sink, I wouldn't be running it at 80c full load.
Its throttling, and its because you have too small of an AIO, I already updated my comment, you're most likely going to need a better cooler, a 120mm is insufficient for a 10600k with a OC, and not even great for stock.
 I'm on a asus z490-v.
My build:
Notes:
One core at 90, the rest in the high 70's/low 80's
My build:
Notes:
Ohhh.... when you said ASUS PRIME, I assumed ASUS Z490 PRIME-A.
That Z490-V might be a problem...the VRM and cooling on that motherboard is not great....
  • Ekwb Custom loop
Again, I was at ~80c. A 10700k is advertised to start throttling at 95-100c iirc.
My build:
Notes:
I thought CPUs throttle when one CPU core is already above 90? But as the other guy said, motherboard is also a factor in the throttling.
I am aware that the power delivery on the board isn't ideal. Any conclusions you can draw from that? Just that the board isn't capable of supporting a 10700k at those clocks? That's fine by me, however does that explain why it's clocks drop so low?
My build:
Notes:
a CPU cooler isn't going to help that much with motherboard VRM temps- and not at all with power delivery, unless it's non-directly-, unless it's like a arctic liquid freezer lol
My build:
Notes:
With HWinfo sensor mode you should see rows that mention throttle reasons
Look for those.
This is wrong. we're talking about Intel CPUs here, they dont run on turbo boost algorithms that scale with temperature to that degree.
Model: HP Omen 17 17-an110ca CPU: i7-8750H (0.125V core & cache, 50mV SA undervolt) GPU: GTX 1060 6GB Mobile (+80/+450, 1650MHz~1750MHz 0.78V~0.85V) RAM: 8+8GB DDR4-2400 18-17-17-39 2T Storage: 1TB HP EX920 PCIe x4 M.2 SSD + 1TB Seagate 7200RPM 2.5" HDD (ST1000LM049-2GH172), 128GB Toshiba PCIe x2 M.2 SSD (KBG30ZMV128G) gone cooking externally Monitor: 1080p 126Hz IPS G-sync
Desktop benching:
Learned something new then, thanks
120mm for a 10700K?,a NH-D15 would perform significantly better.
I would recommend to listen to these replies:
Look for those.
A PC Enthusiast since 2011
AMD Ryzen 5 2600@3.9GHz | GIGABYTE GTX 1660 GAMING OC @ Core 2085MHz Memory 5000MHz
Cinebench R15: 1382cb | Unigine Superposition 1080p Extreme: 3439
i7-10700k
The Intel specified thermal throttling temperature for this CPU is 100°C. Avoid posting information that is not true. It does not help.
https://ark.intel.com/content/www/us/en/ark/products/199335/intel-core-i7-10700k-processor-16m-cache-up-to-5-10-ghz.html
The default 95W power limit for this CPU is not enough to run it at full speed in Prime95. Go into your BIOS and look to see what your turbo power limits are set to. Somewhere around 250W will help avoid power limit throttling. Many Asus boards will set this to the max value which is 4095W. This makes sure that this limit will not interfere with your CPU speed.
Definitely run HWiNFO. It does a good job reporting the various reasons for throttling. It might show VRM throttling if your voltage regulators are getting too hot.
I know. I'm preparing to buy a beefier cooler lol.
My build:
Notes:
20 minutes ago, Brok3n But who cares? said:
best guess, bios is capping you at 90C or 95w, maybe both, a different cooler would solve the temp issue, but not the power limit, you'll have to mess with bios.
5950x 1.32v 5.05 4.55 82C 185w (still testing, likely not stable) R20 12k ll drp4 ll x570 dark hero ll gskill 4x8gb 3666 14-14-14-32-320-28-2T (zen doesn't like timings as much) 1.49v 45C 1.15v soc ll evga 1080ti hybrid (waiting on next gen) ll samsung 970 500gb nvme os ll sandisk 4tb ssd ll all nf12/14 fans ll tt gt10 case ll evga g2 1300w ll w10 pro ll 34GN850B ll x27 ll PA272w
9900k 1.36v 5.1avx 4.9ring 85C 185w (daily) 1.02v 4.3ghz 80w 50C R20 temps score=5450 ll D15 ll Z390 taichi ult 1.60 bios ll gskill 4x8gb 14-14-14-32-280-24 ddr3733  bdie 1.49v 45C 1.22sa/1.18 io  ll EVGA 2080 ti XC 1995//7600 325w 69C stock voltage (bad ocer) ll  8x nf12/14 fans 2x samsung 860 evo 500gb raid 0 ll 500gb nvme 970 evo ll Corsair graphite 780T ll EVGA P2 1200w ll Windows 10 Pro ll NEC PA242w (movie, work mon) 1080p 60hzll Predator X27 4k144 hdr (using at 4:4:4 98 fan is dying)
Was thinking of something along those lines, I'll go check it out along with everybody else's suggestions. Thanks.
My build:
Notes:
oh and for any real world load, r20 would be enough of a test to test power draw and temps at 100% loads, p95 uses something like 140-150% real world power draw, so a 65w setting (like 3.7ghz) can draw 95w. For a 10700k, 4.3 would be about 95w, and 4.7 would be about 135w depending on silicon lottery (make sure the vrm can handle it)
Look for those.
My build:
Notes:
Power limit is something you can set in the BIOS / motheboard.
The i7-10700K is "125W" rated chip. If your OC is hitting the 125W limit, then it will throttle the CPU to keep it within the set 125W.
Again, there should be a setting in the BIOS to increase that power limit ... you can key in "255" or something.
While you have HWinfo open, while running Prime95, check the VRM temperature as well.
Back your comment / question regarding to the the VRM on the motherboard...
There are a couple Z490 boards that are not up to par, for even an overclocked i5-10600K, let alone a i7-10700K.
A lot of ASRock's Z490 boards failed (e.g. VRM exceeds 105*C+, VRM and/or CPU thermal throttles) .
The Gigabyte Z490M (or what is the Z490 UD) was another board with throttling VRMs.
EDIT: Ahh... I remember Hardware Unboxed (AKA Hammer on Box LOL) did some budget Z490 testing...
  • Ekwb Custom loop
i would manually lower the voltages and test slowly until you find the sweet spot for the CPU...
it's usually best to run 100mhz or 200mhz bellow the max clock your CPU could achieve but use much less voltages...that's what i,ve always done.
For example my cpu COULD do 5.0ghz no problem but we're talking north of 1.32v and it gets quite hot for absolutely no worthy performance gains to speak of.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI GTX 1080Ti Gaming X Trio 2ghz OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Rift S
Newegg
