Search In
  • More options...
Find results that contain...
Find results in...
My motherboard won't turn on
motherboard: b365m ds3h (gigabyte) a
cpu:i5 9400 f 2.9 gh
Graphics:gtx  1050 nvidia 4gb (currently unplugged)
PSU:(400 w)
RAM : 16 GB ddr4 3200mh
OS: Windows 10 64 bits
Need more details
what i5?
What ram?
Is the power supply you have TESTED?
Do other things work (turn on?) when you press the power button on your pc?
I am a human that makes mistakes! If I'm wrong please correct me and tell me where I made the mistake. I try my best to be helpful.
System Specs
<Ryzen 5 3600 3.5-4.2Ghz> <EVGA GTX 770 2GB> <16gb 3200Mhz Crucial CL16> <DarkFlash DLM21 Mesh> <650w Corsair RMx 2018 80+ Gold> <Samsung 970 EVO 500gb NVMe>  <MSI MAG b550m Mortar> <Noctua P12 case fans>
What cpu specifically?
CPU: R5 3600 || GPU: GTX 1080 || Memory: 16GB @ 3200 || Cooler: Noctua D15 || PSU: 750W EVGA G2 || Case: Define C
Sorry for the lack of detail I will update the post
1 minute ago, SignatureSigner said:
Need more details
what i5?
What ram?
Do other things work when you press the power button on your pc?
11 minutes ago, Theloy said:
I have a b365m ds3h (gigabyte) a i5
As long as I know graphics card is irelevant
(400 w)
please include full specs regardless of whether you think its irrelevant, also describe the issue more.
Read this.
CPU:
Motherboard:
Ram:
GPU:
PSU:
Storage:
Operating system:
Other:
How have you got the monitor setup, is it connected to your gpu or motherboard (cpu).
preferably Include a picture of your motherboard connected, making sure to include ones that show all the power connection on your motherboard.
People can't help you if you dont include all necessary information.
Does the power supply fan come on?
Does the cpu cooler fan come on?
Have you tested the Power supply?
12 minutes ago, SignatureSigner said:
Need more details
what i5?
What ram?
Nothing turns on and yes the power supply is tested
Have you tested the power button?
System Specs
Yes
unplug everything except the cpu power connected and the 24 pin connector and 4 pin cpu fan connector
Then try again
Then try again
Already tried to make that and didn't worked, thank anyway
how have you tested power supply, on another pc?
Yes this power supply used to be in another pc and worked without problems
try rotating the power switch connector on the bottom of the motherboard, so the word power switch is facing downwards.
I'll be complitly honest with you I don't know what is the switch you are talking of
Nvm you mean the power control cable I tried that it doesn't work
Just looked a little closer at the picture, the power supply looks like a 5+ year old power supply, I haven't seen that 4 pin peripheral in years, (used to be used for CD and IDE HDD) although this will work with hardware that is of similar age but may not to newer hardware.
Or you got a DOA motherboard, Regardless i would get a 80+ bronze power supply at least.
I would get a second opinion on this.
