Connecting to minecraft server running on CentOS 8, please help (!)
Ok, I formatted and removed every partition from the drive, reinstalled CentOS, redownloaded the server but did everything according to this guide instead: https://www.spinup.com/setting-up-a-minecraft-server-on-centos-8/. Everything now works great! Thanks a lot to @Eigenvektor & @Master Disaster for all the help. Edit: I realized afterwards that may have sounded sarcastic, that was truly not the intention. I have however run into a small issue: I cannot for the life of me prevent the machine from sleeping when I close the lid. I have changed pretty much every setting related to the lid in "/etc/systemd/logind.conf" to "ignore". I have also run this command: "systemctl restart systemd-logind", which asks for authorization and then turns my blinking underscore-cursor red. It does not help however. Edit: solution turned out to be uncommenting the lines in the .conf file by removing the #.
