[1080 Ti] max. Voltage draw seems kinda low to me
Solved by Godlygamer23,
12 minutes ago, fuechschen_twitch said:Alrighty, so in case anyone can/wants to check if the BIOS of my GPU was tempered with, I have the file attached to this post. I don't know if it's a needed info or not, but UEFI is checked in GPU-Z.
Also for maybe more help regarding that I have ran a Sensor Log in GPU-Z while having a FurMark-Benchmark active. The results for that can be found in this Google Spreadsheet.
Thank you so much in advance
Also, one other thing...When running Furmark, drivers are automatically set to downclock GPUs, which will also have an affect on voltage. What games have you tried to run altogether? A free benchmark you can use that would tax the GPU in a more realistic manner would be Unigine's Superposition benchmark.
