Text box transfers to other devices
Solved by colonel_mortis,
10 hours ago, Kanna said:I see but do you know if there is a reason for it only happening in dms?
None at all, but the forum isn't doing anything that would try to restore between devices so I don't think there is anything that I can do to control this.
zoneeye ·
Posted in Troubleshooting1 -
leclod ·
Posted in Operating Systems3 -
PatRed ·
Posted in New Builds and Planning4 -
1
1
StormBreakes ·
Posted in Build Logs0 -
3
Jojo0607 ·
Posted in Peripherals4 -
1
play_circle_filled
Latest From Linus Tech Tips:
He Spent 3 YEARS Begging me for a PC. Good Luck Finding it!
