cx650 or cx550m for my build
Solved by RadiatingLight,
the 'm' in CXM simply means "Modular", meaning unused cables can be detached form the power supply in order to make cable-management easier.
If you have a PSU basement (where you can stuff the unused wires), then I would get the CX650, especially since newer GPUs tend to use more power. -- if your case exposes the PSU and you care about cable management, then CX550M might be a better choice, even though it is less powerful.
Both will be more than enough power for your current system.
