Need help changing Wraith Prism for something more convenient
vlatko019x
I have two coolers that I consider buying to replace AMD Wraith Prism. I am using Ryzen 7 1800X with stock clock and voltage.
Those I consider for this matter are Coolermaster Hyper TX3 EVO and COOLERMASTER MasterAir Pro 3
Thanks in advance! ❤️
EDIT:
Got deals for those 3 too:
Cooler Master Hyper H410R RGB,
COOLERMASTER MasterAir MA410P RGB LED TUF Edition and
COOLERMASTER MasterAir MA410P RGB led
Can I ask, why are you limiting it to these two coolers?
Is it price, availability or something else?
System
CPU: Ryzen 5 3600
Case: Phanteks eclipse P400A
Motherboard: MSI B550 Gaming Carbon WiFi
GPU: MSI RTX 3060 TI Gaming X Trio
RAM: 16GB XPG D60G CL16 3200MHZ
PSU: Sharkoon SilentStorm Cool Zero 650W
Storage: Crucial P2 1TB
Why switch cooler when in stock config the stock cooler is enough for that
Reminder⚠️
I'm just speaking from experience so what I say may not work 100%
Please try searching up the answer before you post here but I am always glad to help
Mostly price but I got good deals for
It's too noisy and sometimes not spinning on boot
And is cleaned every one in a while (I did not clean it deep, like detaching it from heatsink or so, just blowing it out)
What case and ram are you using?
Where are you shopping / located? Budget?
  • 2 weeks later...
16 hours ago, vlatko019x said:
My case: https://www.raidmax.com/product_d.php?lang=en&tb=1&id=78
I am located in Serbia and my budget is $40-50
There aren't many upgrade options with a cpu cooler height limit of 145mm.
The MasterAir MA410P doesn't fit. Out of the coolers mentioned, the Hyper H410R RGB is probably the best option.
