Search In
  • More options...
Find results that contain...
Find results in...
M.2 Wifi card and motherboard compatibility
Hey y'all so I just got a new Intel wifi card kit for my MSI B450 Tomahawk Max after my Ethernet port is having issues, and I am having trouble installing the card.
I am confused because in all the videos I am looking at, the m.2 slot is flipped compared to the one on my motherboard. Does my motherboard even have support for the card? Is it the memory only type of slot? I can't find the information I need online. Am I just being stupid? Thank you for any assistance.
Product links: https://www.google.com/amp/s/www.newegg.com/amp/intel-wi-fi-6-ax200/p/N82E16833106102
https://www.msi.com/Motherboard/B450-TOMAHAWK-MAX
There are multiple key types on m.2 slots:
https://www.atpinc.com/blog/what-is-m.2-M-B-BM-key-socket-3#:~:text=on the host.-,The M.,gold fingers) of the SSD.
WiFi and other accessory cards don't use the same key as storage drives.
Unless your mobo also has the correct slot for your card (would be mentioned in the card's specs) you can't use it straight on the mobo. You can however find carrier boards that fit in a PCIe slot.
F@H
Desktop: i7-5960X 4.4GHz, Noctua NH-D14, ASUS Rampage V, 32GB, RTX3080, 2TB NVMe SSD, 2x16TB HDD RAID0, Corsair HX1200, Thermaltake Overseer RX1, Samsung 4K curved 49" TV, 23" secondary
Mobile SFF rig: i9-9900K, Noctua NH-L9i, Asrock Z390 Phantom ITX-AC, 32GB, GTX1070, 2x1TB NVMe SSD RAID0, 2x5TB 2.5" HDD RAID0, Athena 500W Flex (Noctua fan), Custom 4.7l 3D printed case
Dell XPS 2 in 1 2019, 32GB, 1TB, 4K
GPD Win 2
