AMD Ryzen 9 3900x heat issues!
Solved by Vikrant1105,
Might sound like a very basic thing but have you tried re-applying the thermal paste?
I once had a similar issue with my intel based laptop. The temp would spike up and down suddenly and would go through the roof even with medium load. I was able to resolve the issue by cleaning the existing paste and applying a good quality thermal paste.
Ellonmusk ·
Posted in New Builds and Planning8 -
2kPat ·
Posted in New Builds and Planning2 -
Milesqqw2 ·
Posted in General Discussion3 -
play_circle_filled
Latest From Linus Tech Tips:
He Spent 3 YEARS Begging me for a PC. Good Luck Finding it!
