Looking for a Mid Tower ATX PC case
Rotta
Hey!
I have a problem with my current case that I can't fit the PSU cables inside the PC without having the side panel off for my GPU.
I have an RTX 3080 Gaming X Trio and just some normal daisy chain sleeved Corsair PSU cables. Looking for an RGB or non-RGB case as long as it has a controller.
Do all cases have these issues with the 3080's?
First of all, What case do you have now?
Most midtower ATX cases with a place for a 120mm fan in the back should be able to fit your GPU
