Seasonic GX 550w - Will it be enough?
1 minute ago, Euxyh said:I have the arctic 34 duo fan cooler.
That will go just fine without overcloking,
1 minute ago, Euxyh said:Still haven't decided on a case.
Phanteks P400A (rgb or not) are very good. If you get the rgb variant buy 1x 120mm fan for rear exhaust. if you buy the non rgb one get 2x120mm fans on the front for intake.
2 minutes ago, Euxyh said:Why odd going for Intel?
Well ryzne 5 5600x matches and beats 10900k and is 300$ (if found at stock) While it certainly beats the 10700 non k. Also it uses less pwoer so you can get away with 80-100$ motherboard and 30$ cooler. or just 80€ mobo and stock cooler is also fine for ryzen. With intel you need better motherboard to handle the Power usage of their cpus. Als good cooling. That cooler is enoguh for stock clocks at well ventilated case. If plannin to oc consider top of the line aircoolers like Dark rock pro 4
