Search In
  • More options...
Find results that contain...
Find results in...
H510 fan configuration
Hi, so I’m building my first pc and I got the h510 case. I know it’s not the best for airflow but I like the look and I think I can make it work. I just have a question. I’m going to get to fans for the front of the case so should those be set to intake and the fan on the top and back be set to exhaust? Anything helps I just want to get this right so I don’t have to spend more money!
Thanks!
Should have the same basic layout, they cover a bunch of fan scenarios.
