how big of a power supply
Solved by -rascal-,
11 minutes ago, NaGoldfarb said:I did some quick googling and it seems like every generation the recommend PSU jumps 100W. Obviously this cannot go forever there has to be a ceiling.
in 10yrs I dont think that 10,000 watt power supplies will be required, because that would impossible.
Are you looking at TDP, or actual GPU power consumption?
TDP wise...
GTX 680 (2012) -- 195W
GTX 780 (2013) -- 250W
GTX 980 (2014) -- 165W
GTX 1080 (2016) -- 180W
RTX 2080 (2018) -- 215W
RTX 2080 Super (2019) -- 250W
RTX 3080 (2020) -- 320W
Delta (2016 ~ 2020) = ~155W
