Afterburner is only using one fan of my EVGA 1070 FTW2?
Solved by Mark Kaine,
So my conclusion is, in lieu of an actual solution, that you simply cannot control evga icx cards with MSI Afterburner, IF you want both fans to spin.
A serious drawback with EVGA apparently, and all just because they thought "asynchronous fan speeds" would be a good idea (which it isn't, cards runs hotter when one fan is slower, apparently! And also asynchronous fans are obviously louder than when they are synced up, something EVGA should have put their efforts into instead imho)
Tldr: EVGA 1 : Costumers 0
