controlling pump speed depending on GPU temperature or custom sensor via sw
Solved by For Science!,
1 minute ago, Hw87634 said:I have multiple 2 pin sensors, I cannot order right now come temp sensors but I have this: https://www.aquatuning.us/water-cooling/monitoring/flow-indicator/13769/aquacomputer-flow-rate-sensor-high-flow-usb-g1/4
it has a temp sensor inside and check fluid speed... how can be helpful? or should I go straight to some simple G1/4 sensors
It looks like to me that it has the capacity to read off a 2-pin temp sensor but it is not a temp sensor itself. Better just get a passthrough or plug sensor and plug it directly into the motherboard,
