Search In
  • More options...
Find results that contain...
Find results in...
Possible half dead 980 ti.. only DVI works
This has been a problem for the past 2 years with the card. I never noticed it since I use DVI on my main monitor but when hooking up any other output cable the card completely breaks. The card is a 980ti gigabyte model with 2 DVI ports, 3 DP ports and 1 HDMI port. When I plug in anything besides on of the DVI's windows starts running at 800x600 64hz and comes up with a code 43 in device manager, which says the device/driver is not working correctly. Now here's the funny thing, ive been using my TV for the past week with the DP port with no issues and thought a new driver finally fixed it... but came home today to find it stuck again with problems above. I can not wrap my brain around why only 1 port works totally fine, 1080p at 144hz for years and every other port freaks the card/driver out. My only guess is physical damage on the card PCB.
Here's what I've tried below with no success
Clean windows install
Tried multiple driver versions and latest driver
Completely removed any trace of drivers usings guru 3d tool
Multiple HDMI and DP cords
moved gpu to lower PCI slot
Moved PCI power cables to different plugs on psu
At this point i'll take any guesses, half tempted to rip the card out so I can just stop dealing with it.
Thanks yall, CJ
I had this on my current card, 1 dvi, 1 dp port dead. The card still works find with other port.
Last i remember there was a shortage when i plug the port.
theres nothing i can do from the software side. so i conclude the port is dead.
Ryzen 2600 @ 4ghz | Radeon RX580 | 32gb HyperX 3200mhz | 500gb Samsung PM981a | 5 TB HDD | Corsair CX450
