8700k@5ghz temps are higher than I am looking for?
Stueck0514
Hello everyone, I have a question for you guys. This is the first time I have overclocked, and I think I am running into an issue. Here are my specs:
I7-8700k @ 5ghz 24/7, 1.4v
Fractal Design S36 AIO
Asus Maximus Hero Wifi Z390
Corsair 4x8gb 3200
2x1tb nvme drives
Asus rtx 2080ti
650w corsair PSU
I can get 5ghz on all cores but only when I run 1.4v in the bios, but HWMonitor is showing a max of 1.42. I would like to get that down because my temps when gaming are hitting mid 70's. I have already did a delid with conductonaut liquid metal on the die/IHS and on the IHS/AIO. If I can get some screenshots of the BIOS settings I have, I can post them if that helps any. I followed this overclocking guide on youtube and I believe it hits roughly the right spots: https://www.youtube.com/watch?v=bD1Ze80GpLo
If I lower the voltage below 1.38v, it boots to the login screen then BSOD's. Is there anything I can do or have I lost the silicone lottery that badly?
Does that produce some kind of problem?
Primary PC:
No, but I was under the assumption that it would have lower heat output with the delid and liquid metal. My main concern is 1.4v, I know that causes a lot more heat.
At 1.4 volts your temps are not surprising. They are also completely reasonable temps for 24/7 operation.
Primary PC:
70c at 1.4 seems normal. I see 55-60 at 1.32 delided at 5.0.
Main RIg Corsair Air 540, I7 9900k, ASUS ROG Maximus XI Hero, G.Skill Ripjaws 3600 32GB, 3090FE, EVGA 1000G5, Acer Nitro XZ3 2560 x 1440@240hz
