Radeon Software: Host Application causing abnormal CPU usage and high idle temps
Solved by Moonzy,
2 minutes ago, Ratchet7989 said:
it's "Instant Replay" and it's off
was thinking if u had it on, with desktop capture turned on as well
guess it wasnt the case
then i have no clue other than suggesting a full OS reinstalling if DDU didnt work out for you
wait for other's insights
