RTX 3060 ti Pin adapter ?
Tuan
I'm still new to all of this ( build my firsts pc a few months ago ). I was lucky enough to pick up a RTX 3060 TI today. I'm currently using a 2070 super. the 2070 uses 1x6pin and 1x8pin, while the 3060 ti uses 2x8pin. Would I need to buy an 6 to 8 pin adapter if I want to use the 3060 TI without changing my power cables? and if you could link me on amazon just to make sure I buy the right one would be very much apricated. Thank you.
my current build
2 minutes ago, GoodEnough said:
3060ti i think only requires one 8 pin connector
Thats for the reference design of the 3060ti this specific gpu has 2x8pin
13 minutes ago, Tuan said:
I'm still new to all of this ( build my firsts pc a few months ago ). I was lucky enough to pick up a RTX 3060 TI today. I'm currently using a 2070 super. the 2070 uses 1x6pin and 1x8pin, while the super uses 2x8pin. Would I need to buy an 6 to 8 pin adapter if I want to use the 3060 TI without changing my power cables? and if you could link me on amazon just to make sure I buy the right one would be very much apricated. Thank you.
my current build
there are some 6 pin to 8pin adapters that have another power source like molex or sata power supplementing the 6 pin to make up the difference but these methods are usually not recommended. But as for if your gpu requires it that is most likely the case as many times companies like ASUS, gigabyte and MSI tend to factory overlock their top tier gpu's causing higher power draw than the OEM spec
i can only assume if it has a 2x8 pin then it also has a duel bios, one bios being balanced and only needing one 8 pin while the other is for overclocking needing both 2x8 pins
Your power supply should have at least 2x 8 pins already, the 2 extra pins that hang off when you use the 6 pin can be bundled on to make an 8-pin.
my current build
The EVGA 650W GM should already have 4x PCI-E 6+2 Pin connectors.
On that existing PCI-E 6-pin, just connect the loose 2-pin to make it an 8-pin.
You'll have 2x PCI-E 8-pin power connections. Good to go.
https://www.evga.com/products/product.aspx?pn=123-GM-0650-Y1
$1.80 (Free Shipping) BK ESTLUCK PCIe 6-pin to Dual 8-pin(6+2) Video Card  Power Adapter Cable (6-pin/2*8-pin(6+2), 40cm +20cm) at m.FastTech.com -  FastTech Mobile
Intel Z390 Rig ( *NEW* Primary )
Intel X99 Rig (Officially Decommissioned, Dead CPU returned to Intel)
  • i7-8086K @ 5.1 GHz (still tweaking) -- i7-6800K
  • Gigabyte Z390 Aorus Master -- ASUS X99 Deluxe
  • Sapphire NITRO+ RX 6800 XT Special Edition Sapphire NITRO+ RX 5700 XT Special Edition -- 2x Sapphire NITRO R9-Fury in Crossfire
  • 32GB G.Skill TridentZ DDR4-3000 CL14 (16GB TridentZ RGB + 16GB Red/Black TridentZ)
  • SanDisk 480 GB SSD + 1TB Samsung 860 EVO + 1TB WD SN750
  • EVGA SuperNOVA 850W P2 + Red/White CableMod Cables
  • Phanteks Enthoo Luxe Tempered Glass Edition
  • Ekwb Custom loop
  • Logitech G502 Proteus Spectrum + Corsair K70 (Red LED, anodized black, Cheery MX Browns)
AMD Ryzen Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
Intel Z97 Rig (Decomissioned)
  • Intel i5-4690K 4.8 GHz
  • ASUS ROG Maximus VII Hero Z97
  • Sapphire Vapor-X HD 7950 EVGA GTX 1070 SC Black Edition ACX 3.0
  • 20 GB (8GB X 2 + 4GB X 1) Corsair Vengeance DDR3 1600 MHz
  • Corsair A50 air cooler  NZXT X61
  • Crucial MX500 1TB SSD + SanDisk Ultra II 240GB SSD + WD Caviar Black 1TB HDD + Kingston V300 120GB SSD [non-gimped version]
  • Antec New TruePower 550W EVGA G2 650W + White CableMod cables
  • Cooler Master HAF 912 White NZXT S340 Elite w/ white LED stips
AMD 990FX Rig (Decommissioned)
  • FX-8350 @ 4.8 / 4.9 GHz (given up on the 5.0 / 5.1 GHz attempt)
  • ASUS ROG Crosshair V Formula 990FX
  • 12 GB (4 GB X 3) G.Skill RipJawsX DDR3 @ 1866 MHz
  • Sapphire Vapor-X HD 7970 + Sapphire Dual-X HD 7970 in Crossfire  Sapphire NITRO R9-Fury in Crossfire *NONE*
  • Thermaltake Frio w/ Cooler Master JetFlo's in push-pull
  • Samsung 850 EVO 500GB SSD + Kingston V300 120GB SSD + WD Caviar Black 1TB HDD
  • Corsair TX850 (ver.1)
  • Cooler Master HAF 932
