Rattling noise from GPU fan
Solved by DoctorNick,
Just now, Sir Asvald said:I don't want to risk breaking it..
Should be fairly straight forward. Remove the 2 screws. Might have screws on the other side as well. Check back I/O of the card for screws. Check if the DVI plug's 2 screws is inside the shroud. Go go go
Meaker 路
Posted in Graphics Cards0 -
3
Harflite 路
Posted in CPUs, Motherboards, and Memory5 -
kacper6768 路
Posted in Programs, Apps and Websites1 -
ID0 路
Posted in General Discussion4 -
asususr 路
Posted in General Discussion1 -
specsdude99 路
Posted in CPUs, Motherboards, and Memory9 -
5
5
14
play_circle_filled
Latest From ShortCircuit:
The World's Fastest CPU (Technically...) - Intel i9-14900KS
