Low +12V problem. Solved.
No, the voltage MUST be withing 10%, prefferably within 5%. It should be within 11.7v ... 12.3v
Mechanical hard drives have motors which are designed to run at 12v, if the voltage goes outside some reasonable range, the rotation speed will be different and the hard drive will have a hard time finding the data on platters, if it would work at all.
The VRMs (dc-dc converters) which power the processor and the video card also expect to have a voltage close to 12v, they're "optimized", the components in the circuit are carefully picked so they work well with a voltage close to 12v - if it's too far from 12v, those circuits can overheat, or "hiccup", or cause other issues which can damage those components over time.
A switching power supply constantly monitors the output voltage and adjusts the switching frequency to send fewer or more pulses through that transformer, to keep the voltage very close to 12v. Some power supplies will be designed to output a bit more like 12.2-12.3v on purpose to account for voltage losses on the wires between the power supply and components.
So something's wrong with that power supply, either in the feedback mechanism or with its voltage referece.
Be careful though to actually measure at the 12v connector, not the -12v wire in the 24 pin connector. The easiest would be to insert the meter probes in a molex (hdd) connector, the black and yellow wires in the plug.
The -12v can be -10v or even -8v, it's a very tiny power supply (usually under 1A) and it's only used by the motherboard for the serial ports, and even then the serial port circuitry on a motherboard only consumes a few mA of current.
So without anything connected to -12v, nothing actively consuming power, the power supply is not "working hard" to keep the voltage very close to -12v.
