Would appreciate some help with case recommendation
Emeth
Hi, I'm going to be doing my first ever Ryzen build, coming from an old 6700 non k.
I already got all the components:
MOBO: Gigabyte X570 AORUS MASTER
GPU: Gigabyte 3080 Gaming OC
CPU: AMD Ryzen 9 5900X CPU Cooler: LIAN-LI Galahad AIO 360 Liquid Cooler White
PSU: be quiet! 850W DARK POWER PRO 11
RAM: No sure yet, probably some kit that has B-die C16 3600-3800
Fans: 6 Noctua SF-12A (can get more)
I spent days looking at different cases from corsair, Lian li and a few others and I just can't make up my mind
I can't for the life of me figure out what to put this in, I was thinking about some of the Lian-Li cases but most of them are either out of stock here or only support an SFX PSU.
I would like a case with an easily removable dust filter (magnetic pref), it's really dusty where I live so I have to clean the filter regularly.
I'm also going to be using the Lian-Li strimmer extensions (both psu and gpu) so if there's a case that makes these look nice that would be great.
Appreciate the help, thank you.
I use a fractal design define r6. There is also the define r7. I like them because you can do everything with them. They have a HDD cover if you want to use a lot of HDDs, you can also put it in the back for an open layout, you can simply remove the solid top panel for top exhaust, it has dust filters which are easy to remove, it has a fan hub and it is a pretty good compromise between airflow and noise dampening. Also it has an optical drive slot behind the front door in case you need it. I use it with 3 be quiet! Silent Wings 3 140 mm PWM and it is insanely quiet.
But it looks not that impressive and it doesn't have any RGB.
If you want RGB, I like the look and quality of the Phanteks Enthoo Evolv ATX Glass
If you want a lot of airflow: Phanteks Eclipse P400A or Meshify Series from fractal design.
My build:
CPU
Intel Core i7 9700 8x 3.00GHz So.1151
CPU cooler
be quiet! Shadow Rock Slim
Motherboard
MSI B360-A PRO Intel B360 So.1151 Dual Channel DDR4 ATX
RAM
16GB (4x 4096MB) HyperX FURY black DDR4-2666
GPU
8GB Gigabyte GeForce RTX2070 WindForce 2X 3xDP/HDMI
SSD
500GB Samsung 970 Evo Plus M.2 2280
HDD
4000GB WD Red WD40EFRX Intellipower 64MB 3.5" (8.9cm) SATA 6Gb/s
Power Supply
bequiet! Straight Power 750W Platinum
Case
Fractal Design Define R6
3x bequiet! Silent Wings 3 PWM
Where is here? So we can help look.
And I like the Lian Li Lancool line myself.
My 2020 Upgrade: CPU: Ryzen 5 3600; MB: MSI X570 Tomohawk WiFi; Memory: G.Skill Ripjaws V 32GB 3600 MHz; Case: Lian Li Lancool II Mesh Performance; PSU: Corsair RM550X 80+ Gold; Storage: WD Blue 500GB SSD; Seagate 4TB Compute HDD; Monitor: GIGABYTE G34WQC 34" 144Hz Curved Gaming Monitor, 3440 x 1440 VA 1500R Display
Previous Components Still Using: GPU: MSI GTX 1070 (bought Used); Storage: WD 3TB Green HDD,WD 1TB Black HDD, SanDisk SSD PLUS 240GB
Previous Monitor I want to VESA mount: LG 29UB55-B 29" Ultrawide 1080p 60Hz IPS
I have the Lian Li PC-O11 Dynamic.
Enough space to build your system in and good airflow.
Also nice looks imho.
Only thing to watch out for the the height of your GPU if you want to install a waterblock :P
No waterblock shouldn't give you any issues
